Master List of DIY available waveguide dome tweeters
Reactions: hifijim
As @Jeffh01 mentioned the WG300 is no longer in production.
I have made an accurate drawing with dimensions taken from a plaster replica cast from the original.
Not sure if it's okay for copyright reasons to post it here, but I guess it should be okay as the waveguide is no longer in production.
Let me know if there is any interest.
Good to know. I'll remove it from the list. I think Heissmann is working on something similar. I imagine you'd be fine to share, especially since you wouldn't be profiting off of sharing the plans. I am not a lawyer though!
Reactions: stv
Some nice waveguides for dome tweeters are available here: https://audiohorn.net/tweeter-waveguide/ along with their horns for CDs and other kinds of tweeters.
Bliesma T34 waveguide designed using ATH here: https://cults3d.com/en/3d-model/various/ath-dome-t34b
Added.
You could also look at the tweeters with waveguides at Heissmann Acoustics (LINK). Most of them use the Monacor WG-300 waveguide with an adaptor plate. You can buy the adaptor plate and they have the instructions to DIY one.
If we can identity a suitable alternative to the WG300 from Monacor (3D files presumably), then I will add it. As has been said in the thread though, WG300 is no longer in production
Here is my WG 300 drawing as 1:1 PDF and a corresponding DXF (units are millimeters).
The WG shape is made using a spline connecting several measured points.
Please note that the drawing as provided by different vendors (and supposedly also by monacor themselves) has a wrong depth dimensioning:
I also attach some photos for better understanding of the geometry!
  • WG300.pdf
    WG300.pdf
  • WG300_DXF.zip
    WG300_DXF.zip
