My Prodigy sometimes makes a clicking sound:
MartinLogan Prodigy clicking sound - YouTube
After consulting with ML I replaced the power supply and then the transformer with new replacements and it still didn't completely fix the issue (though it seemed to happen less frequently).
After a few months it largely went away, I may get a few clicks every month or so.
Lately it's starting to happen more frequently again (maybe once a week, and when it happens it does that on and off for minutes).
Any idea what causes that? It's not the panels, those were replaced and I also swapped them between the two speakers and it stayed with the same speaker. Vacuuming didn't help.
Hi...i have working on ML panels for about 20 years..I have seen this before,
It could be one of the 3 wires that runs from the bias boards an step up transfourms, right were these wire connect....
An the 3 wire connectors ends that go to the panels.
I have put tape on each of these connectors.
It seen to do this when there more humidity around.
all just mans findings......good luck
Hi tyu,
It makes sense that it's a connection issue, because all the possible part have been replaced with new ones. And I live in Singapore which is VERY humid all year round.
Would it help if I just put some desiccant inside the speaker to reduce internal humidity? If not can you point me which wires to look?
