Marshall MB series B150 one channel not working
Well, I got the amp working, but when I plug a set of headphones into the jack, it sounds kind of crappy, no hights, plenty of mids, no low end.
And when using the CD IN jack (right next to the headphone jack), it is even more pronounced.
I'm aware that you cannot expect a 15" full range speaker to sound as good as a hifi system. But from a build in designated headphone amp?
When I took out the preamp pcb, I noticed a pair of transistors TR41 & TR42, both J111. With the pcb disconnected and out of the chassis, TRs still soldered in place, they show 20 ohms between gate and source. I don't know if this is ok.
There may be other issues with that pcb...
