Ok, so this is my first cab project. I read a couple of the posts to help me but i'm really confused. What is confusing to me is the impedence. I don't get it. So basically i have a choice to buy either 8 or 16 ohm speakers. I don't have a head, but i do intend to buy one (it will be a marshall). So first, is there any good site (or person) that can thoroughly explain impedence to me? Second, what kind of choices of amp heads do i have when choosing 8 ohm or 16 ohm? I'm really confused. Thanks for any help.
Don't worry, it's all really rather simple. This site should provide a good explaination of impedence. As for which heads will match your speakers, most heads have an impedence selector switch to match to a cabinet. Simply select the desired impedence, and you're ready to rock. Also remember that you can connect speakers in series or parallel, which will yield different impedences (16 ohms and 4 ohms for 2 8-ohm speakers, respectively). Speakers behave just like resistors in this aspect.
I hope I have been able to help you in some way.
Merry We Meet,
Matthew
Merry We Meet,
Matthew
What kind of advantages/disadvantages appear when deciding 16 or 8 ohm? That site helped out a little, but it is still a little confusing. After hearing that you can select the impedence on the head, that kind of relieved me. One question, when connecting speakers in parallel, how do you calculate impedance? it didn't explain it well enough.
In series resistances add, and in paralell you calculate by 1/(1/R1 + 1/R2 +... etc). Simply, two identical resistances in parallel are half the individual resistances.tareqx2 said:What kind of advantages/disadvantages appear when deciding 16 or 8 ohm? That site helped out a little, but it is still a little confusing. After hearing that you can select the impedence on the head, that kind of relieved me. One question, when connecting speakers in parallel, how do you calculate impedance? it didn't explain it well enough.
With 4 speakers, you can either
a: wire two 8R in series, the other two in series, then parallel them to get 8R. 8R +8R = 16R, Same for the other pair. Both pairs in parallel gives a net of 8R.
b: Wire all four in parallel for 2R. Not recommended
c: Four 16R speakers in parallel for a net of 4R.
d: same as a: with 16R drivers to give a net of 16R.
I'd go with option a: myself.
Another option would be c: with two seperate cabs as per suggestions below. That way you can use one cap or two depending on the venue and get an 8R (1 cab) or 4R (2 cabs) and use the appropriate tap dependig on what you use.
A tube head has an output transformer in it to match the low impedance load of the drivers to the high impedance that the tubes want to see. If you connect the speaker to the correct tap the amp will give it's max power potential.
Here's a link to the old EVM12L (a superb guitar driver) datasheet which shows how to wire in series and parallel.
http://archives.telex.com/archives/EV/Speakers/EDS/EVM-12L EDS.pdf
Some other points.
Build them as 2 2x12 cabs. It'll add about 2kg to the total weight, but it makes them a hell of a lot easier to move. You can also stack them vertically on a small stage. An added benefit of this is no horizontal phase cancellation between the drivers and better projection into the room. It also puts some of the drivers near ear level which IME means you'll tend to play at more sane levels. Four twelves can move a hell of a lot of air. This doesn't look 'traditional' so is a negative to some I've suggested it to in the past, but it works better.
Use good quality ply and brace the boxes well. Cover them in spray on pickup truck bed liner. It's as tough as hell and not that expensive by the accounts of bass DIYers I know in the US. Will also neatly cover any slight imperfections in woodwork and is hard to mark it up. Tolex looks like dirt after it's been gigged for a while and carpet pickups up smells.
Use Neutrik Speakon connectors on the cab(s). Tough reliable and aren't apt to get kicked out by someone on stage or go noisy like 1/4" jacks do. Premade leads are cheap and with lots of options for the amp end depending on what you need there. They're the industry standard now in PA.
Buy a cheap furniture dolly and nylon cinch straps to move them. Save your back. Two smaller boxes fit better into a lot more vehicles than a 4x12 which will be an awkward shape at the best of times.
Unless you're Hetfield and actually playing huge arenas you don't need a big head. It won't get much grit at realistic volumes. Try smaller heads, esp if you're playing trad bar gigs where 15 or 30W will likely be enough in reality and sound better too as you'll be capable of pushing it into distortion at a sensible volume.
Unless you really have to have a factory Marshall, build a clone if you like to DIY. You can also tailor the sound to what you want and add other features. I built a 100W head (now runs re-biassed with one set of output tubes for 35W) for a friend, and it ended up with 3 tube channels in it, all footswitchable and all very different sounding. I did it as a love job and it didn't cost that much in parts. The extra pre channels would probably cost $US50 add 1kg to the weight. Now he has a cab that he can play any gig with because of it's flexibility. For smaller bars, you could also just take one 2x12 and a milk crate to put it on.
I also just handed a harp amp to a friend to test. It's an EL84 based design of about 15W with two EVM12L drivers and it's just too loud. I added a triode switch so it's 3W with a different tone (softer, sweeter). You don't get these options on most commercial amps.
Turn it down. I'm a bassist, it's my job to tell you that.
It's shockingly rare to find a guitarist that plays at sensible volume that the rest of the band doesn't have to play even louder to compensate for. In most small/medium venues this can make it unpleasant for the audience too. Loud is fine, but lots won't enjoy painful loud, especially the women and if they don't stay, either will the guys and the owner won't book you again.
Sorry if I'm ranting, it's only meant as advice and I hope I'm not preaching to the converted. But I don't see the need for a guitar 4x12.
Thanks for all the info Brett, i do agree with the 2x12 idea. Its just that for my first project i was really focused on a 4x12. It doesn't have to do so much about the sound rather than the fact that i can say that i made it. My idea is to build a Marshall 1960ax cabinet (found here) the info on connecting speakers was very helpful. I am going to go with your choice a. Thanks for the schematic as well. In the future i will be looking into making a 2x12 most likely. for now i am going with this though. Thank you for your help.
Hey, how come it says that if you use the Marshall 1960ax as a half stack with a 100w head that it is recommended to use a power break? What is a power break? Another question. would the head i buy for the amp have to be 100w or could it be like a 50w tube head? kinda confused me because the Marshall vintage-modern head is 50w tube and the cab for it is 100w.
As I said earlier, I doubt you'll ever need 100W on stage for guitar. Go with the 50W (but you wont even need that much) as it'll break up earlier at more sane volumes.tareqx2 said:Hey, how come it says that if you use the Marshall 1960ax as a half stack with a 100w head that it is recommended to use a power break? What is a power break? Another question. would the head i buy for the amp have to be 100w or could it be like a 50w tube head? kinda confused me because the Marshall vintage-modern head is 50w tube and the cab for it is 100w.
A power brake is basically a big variable resistor the soaks up a lot of the wattage put out by the amp so that you can get the clipping / overdrive / distortion from the power stage without being so loud you can hear it in the next postcode. Use a smaller head, therefore no need for a power brake. Marshall just want to sell you more stuff.
Also, it sounds as though you don't understand the difference between amplifier and speaker power ratings. I'll explain later if you need it clarified.
Clarification would be great. As i said it is my first amp project, i play guitars, don't make them 😉
OK. Speaker rated power is how much the speaker itself can handle before damage. Lets say you plugged an electric organ into an amp (any amp would do) which is rated at greater than 100W and pressed and held down some of the keys on the organ. Whilst doing so, you measured 100W being delivered into the speaker. You place a brick on the keys and walk away, with 100W going into the cab. If it's rating is accurate, eventually, there'll be damage to the speakers of some kind. And everybody for miles around will hate you. The 100W rating of the speaker is how much power it can absorb for a period of time before there is damage. It's not about how much it needs to make a decent sound in terms of loudness or tone. The speaker only absorbs how much power it's given by the amp.tareqx2 said:Clarification would be great. As i said it is my first amp project, i play guitars, don't make them 😉
I used the organ as it's capable of generating a tone at a constant level, unlike a guitar. This is important as guitars give out a much less constant volume as you shift chords etc and strike the strings at different pressures so only on the peaks will you potentially be giving the speaker full power and even then it depends on whether you turn it up enough to do that. With a guitar amp, part of it's 'tone' is the distortion it can generate when it's over driven, or giving more than it's rated power, eg 100W in the case of the Marshall. The trouble is, guitar speakers are very efficient, especially 4 x 12" so they need very little power to go very loud. As you're only using a small fraction of the amp's power, even strumming hard, powerchording etc you're not going to get the overdrive, because the amp may only be putting out a few watts. Hence my earlier recommendations for a smaller amp and to be able to split the 4x12 into two 2x12 so you can get the tone of the amp breakup at different volumes.
Using a power brake is a bit like having a powerful car that you love the sound of up at high revs, but you can't use them around town, so you drag a very heavy trailer around so the engine has to work harder to get those nice sounding high RPM's. Same thing with the amp that you want to run at 100W to get the tone, but you deafen everybody around doing it, so you need a way to get the amp to make the power, and divert some of it off to the powerbrake to get the volume lower.
Marshall stacks and 100W amps are from an era when decent PA's were far less common, and nowhere near as good as even cheap stuff today. Back then all the guitar sound that the audience heard came from the stack. Now it's often from the PA, and even if the audience is getting it from the stack on stage, ie no PA support, then with OH&S and noise rues etc you simply can't use it to it's capacity. They're still made because of tradition and people want them because they think they're "it". And of course Marshall are happy to keep making them and making money off them if the punters will pony up for one, whether they need it or not.
Once you've built the cab, try to borrow some amps of different powers and try them, and then you'll find out what you need.
My housemate plays in a really loud metal band. He's got a 100W Sovtek head and 2 4x10. Even at the loudest venue around here (Marquee) he uses one of the 4x10 and barely has the amp turned up much at all and gets all his distortion from a pedal. Last gig he used a Crate powerblock and swears he's never humping the heavy tube amp out again.
Just a quick question. What kind of wood would you recommend for building this cab. I am planning to use birch plywood for the front part, but i'm not sure if i should. I'd rather have the advice from an experienced diy'er. What wood should i use for the sides, for bracing the cab and the front plywood?
Good quality birch plywood is usually the material of choice!, a cheaper option (which is also more acoustically dead) is chipboard or MDF - but it's not as strong and long lasting as the ply. For a slightly cheaper option, use ply for the front, and chipboard or MDF for the rest. But if you can afford ply, or already have it, use ply.
For batterns, pine or any softwood is fine.
I wouldn't recommend anything but ply for this application, MDF and chipboard just aren't roadworthy.
What he said. And cover it in pickup bed liner. Indestructable.pinkmouse said:I wouldn't recommend anything but ply for this application, MDF and chipboard just aren't roadworthy.
Hey brett, I got a question for you. You said in an earlier reply that you built a tube head for your friend. That kind of intrigued me to look into it. I got a couple of questions about it before i consider it though.
1) how hard is it to make? (although this question doesn't matter that much because i enjoy a challenge, i just want to know how much i am going to have to focus on this)
2) how much is the price range?
3) how is the sound quality to price ratio? is the sound that of a 1000$ head?
4) How would i start it, did you start from scratch? Maybe a introduction tuturial from you would be helpful, you've been really helpful so far.
Hope you don't mind answering these questions. So far the cab project is going good, i am almost done and it is looking cool.
1: I don't find it hard, but I've been doing it for years. If you're patient, methodical and safe, I see no reason why you couldn't build one.tareqx2 said:Hey brett, I got a question for you. You said in an earlier reply that you built a tube head for your friend. That kind of intrigued me to look into it. I got a couple of questions about it before i consider it though.
2: Hard to say. Case can add a lot to the cost, but if you can build it, perhaps not much. Parts cost depends on what you want to build, and how much power. I also have trade accounts at some places and get discounts.
3: SQ/$; can be very good, but the advantages are that you get to specify what features you want. For example, I once built one with multiple seperate channels and EQ, footswitchable, and because it was designed from scratch this way, didn't add a lot to the cost. Even if it's something like adding a transformer DI out, or a buffered tuner out, you can do that easily.
You can certainly do as well as new amps for similar(ish) money. You get great value with a lot of used amps, esp if the tubes are good and the unit has been well cared for.
Another advantage to a DIY build, is that you should never need to have to pay a tech to work on it again.
4: I build from scratch, either modded or origiinal circuits, but there's nothing to stop you building a clone of something either. If you have a particular tone in mind, then I'd suggest this as you should get pretty close to the commercial unit. For some brands replscement / aftermarket transformers are available, eg Mercury and Heyboer.
www.ax84.com have lots of projects, and maybe even some mp3s. That'd be a good place to start.
There are kits available out there too, but I've not had anything to do with them, so have nothing specific to recommend. Kits are the best for first timers as they're already though out and packaged and have a much greater chance of working first time and with fewer issues.
Morgan Jones' Valve Amplifiers and Building Valve Amplifiers are well worth the money to understand what's going on.
http://tone-lizard.com/Table_Of_Contents.htm also has some interesting takes on classic amps and the myths areound them. I mostly agree.
I'm reluctant to post one of my circuits for you to build, as tone is such a personal thing. I'm also not a guitar player so don't have the depth of understanding of tone to be able to guess well what you might like when you're on the other side of the world. I use a guitarist to play and describe what they want different, mod, then retest until they're happy.
If you want to get into electronics, this can be a great experience and a lot of fun. But it'll also take a lot of time, may cost more than a commercial product new and will have little resale value.
You really need to think about all of this before you commit to such a project.
Hey, i know i'm kinda jumping around on topics here but how do i wire the speakers to the input/output jack? I know how to wire the speakers together, but when i get the two wires at the end, how do i wire them to the jacks? Oh by the way i am talking about the 4x12 cab.
I understand how i have to wire the speakers together, but what i don't understand and it doesn't show it in the speaker pic that you gave me, is where to hook up the wires after all the speakers are wired together. Like, after i wire the 4 speakers together I will have 2 wires left to hook up, the positive and negative wires from the speaker, so how do i hook up these wires to the input jack and the output jack from my cab. Maybe i am wrong, i guess a better first question would be, does a cab have an output jack?
- Live Sound
- Instruments and Amps
- Marshall 4x12 cab
