Marantz PT rewire EU/US to US only
Hello. Model CD275 with VSS: designed with a Voltage Selector Switch for int'l use. Thanks to fellow member 'joydivision' for assistance to get started. I want to eliminate the VSS and hardwire to the PT. The 1st attachment are his instructions for rewiring primary leads.The Marantz schematic found in HiFi engine doesn't show wire insul. colors & I need help. Thank You. Today: 03 Sep, with a magnifying glass I was able to see molded numbers on the interior of the green switch plate of the volt. adaptor corresponding to schematic numbers. One step closer. I apologize for the non viewable pictorial attachments. I will try again.
