Hi all.
So I bought a Marantz NR1605 A/V off of eBay "as-is". The description reads:
Marantz NR1605 AV Receiver As Is, no returns or guarantees Shipped with USPS Parcel Select Ground. This was a new receiver purchased in approximately early 2015. The receiver still turns on but I think during a power outage/surge something happened to the HDMI in/out capabilities. The receiver is included with the adapter, manual, and remote control
They are correct - it does come on but only for a few milliseconds before turning off. I bought it thinking that it probably would just be a blown fuse or something I could see a burnt component on the board that I could replace.
Opening it up I found a total of 4 fuses. Each fuse looked just fine. Nothing blown. Examining the board(s) inside they all seem clean and shinny/new looking. Nothing on the board(s) look burnt or leaking in any way.
However, I am unable to figure out what the steps are in order to take each PCB board out in order to see what beneath it - if there are any more fuses or check for something burnt/leak.
I have taken a good amount of pictures in order to let you see what I am seeing. Perhaps you would be able to spot something that I have not. Or better yet, let me know how to go about taking the PCB boards out. I also have 2 videos showing it [URL="https://www.dropbox.com/s/yjb98avhwpsrfwz/20200815_141224%20%281%29.mp4?dl=0"]coming on and then off[/URL] and also what it looks like on the LED screen when it comes on.
ALL Images here
ALL Images here
same problem with my NR1605
Hi stealthrt,
I have exact/similar problem with my Marantz NR1605. I also made some troubleshooting without schematic diagram(I can't find one) and I was not able to pinpoint what causes the amplifier to switch to a "protection mode". But what I noticed is that, when I unplugged the Speaker Board Power Connector and then turn on the Power, the unit can be turned on and the problem with blinking disppeared. So i suspect that problem the lies on the Speaker Board but I don't which component. It would great if someone from this forum could help shed light on this.
By the way, how's the status of your NR1605?
Regards,
Tontay
Hi stealthrt,
Regards,
Tontay
