Marantz CD6000 power switch
Guys, I was damping and putting bypass caps on my CD6000 and must have jammed the power switch that connects to the long plastic arm that turns on the unit.
If I hold the power button on the front of the unit all the way in, it comes on, if I release the pressure at all it turns off.
Can the switch in the box be repaired? If so how?
If I need to replace it does anyone know the part number and where I might find one?
See below for the switch box.
Thanks, Nut
They have a little spring-loaded latch on <-> latch off mechanisms underneath.
Search for the part number (which I can not read from the photo due to poor quality)
... but, you only have to clip the black plastic thingy onto the first indent; NOT the second -> and that's all - the switch will probably work just fine 🙂
