ash_dac said:Hi,
Does anyone have the Marantz cd52 service manual ?
Hi.
http://www.yourfilelink.com/get.php?fid=33785
Andy
Have you modified one?
I've got a dpa little bit that uses the sa7350, and it sounds pretty good.
CD 52 Manual
I have reposted the manual here :-
http://www.yourfilelink.com/get.php?fid=217623
Good luck.
Andy
Malefoda said:Hi,
is the manual still avalable?
Good luck.
Andy
Hello everybody.
I am also looking for the CD-52 service manual.
None of the above links work.
The problem of my CD-52 is that it is impossible to read a CD after about one hour of work.
The light "error" appears when trying to read, even when changing CD.
I have opened the cover case. It looks like that the motor does not turn any more. The inside CD remains fixed.
When shuting down the CD player for more than 2 hours and restart, the motor runs again for a few minutes and will stop again.
Does anyone has got the same problem how did you solve it ?
Thanks in advance for the help.
Gab
Gab
why pay for this?
it's free on this very good page...... 🙂
http://home.quicknet.nl/qn/prive/ra.vdsteen/
thanks a lot 6h5c 😉
thanks a lot 6h5c 😉
Hello
The free above link does not work. It is relinked to the Marantz.com which reply is impossible to display the page !
Any other free link ?
Related questions :
How to know if the laser diode works ?
Whether a CD is in the drawer or not, should the motor starts running or not when the drawer reaches its read position ?
In my case, the laser diode moves the center and tries to detect a CD but the motor never runs, either a CD is here or not !
I have tested the motor alone and it runs correctly.
The failure seems to be somewhere in the command of the motor but without any schematics, it's not easy to repair.
f6dqm1
Related questions :
f6dqm1
strange, strange
so, if you just paste the link on the navigator, it's ok.
if you want another datasheet, you can go on this best french forum in all the world!!!😀 😀 😀
http://www.ls3-5a-forum.com/cgi-bin/yabb/YaBB.pl?board=1amplis;action=display;num=1118867586
Pour le Manuel Technique gratuit / For the free service manual :
Service Manual free download,schematics,datasheets,eeprom bins,pcb,repair info for test equipment and electronics
- Digital Source
- Marantz cd52 service manual
