Maplin prosound 1600 amp.
These amps are bugdet type and have a few floors in there design..ie not enough output devices for there give output rated power...
Yes most of us would bypass them and use better branded amps out there etc...
Now this one came to me with tripping the circuit breaker when powering up?
Well after look over things, I did notice the soft start seem to be missing one thing...a ntc or large resistor to aid in the in rush. All they have done is fitted a cap across the relay and so at power on there would be a big arc inside the relay!!!
So via adding a 33r or 47r in line with the mains in and powering on you get that slow inrush and no trippig.
So for the cost of a ntc etc..geee come on design team pop one in!!!
