I need to know how many voltage supply rails of these model, also current each channel 🙂
S/550E
SA 3.9E
SA 4E
SA 12E
Anadigit
S/550E
SA 3.9E
SA 4E
SA 12E
Anadigit
I'm sorry to say that I don't have that data. You can calculate it
fairly easily knowing the rated power of each amplifier and adding
about 10 volts to the voltage required to reach a peak wattage of
twice that power.
There was no current limiting to those amplifiers as I recall, so the
current was pretty high.
twice that power.
Thanks PAPA
I seen 2N5566 in the front end of S/550E, could I use 2N3958 instead of 2N5566 ? (also 2SK170, 2SK389, 2SK129A)
Thanks for advance
Anadigit
Thanks for advance
Anadigit
SA/3.9E !?!
I never heard Threshold have SA/3.9E in line production !
Could anyone show it schematic ?
MPS-U10 and MPS-U60 are hard to obtain parts, Did someone have idea for substitute them ?
Anadigit
Anadigit
The SA3.9e was one of my favorites.
I have the schematics up on passdiy, but we changed the server
and I don't recall the new passwords, so I'll check tomorrow at work.
I have the U10's and U60's if you need them desperately, email me.
125W model ?
Thanks PAPA but I can find them in my local shop already.
I decide to build 125W version, How do I select correct supply voltage rails ?
Also bias adjustment 🙂
Anadigit
Anadigit
Re: 125W model ?
125 W = 250 watt peak.
V^2 / 8 =250
V^2 = 2000
V peak = 45V
Add 10 volts or so, V supply = +/-55V
Bias it for heat sinks at 50-55 deg C.
ANADIGIT said:Hi,
I decide to build 125W version, How do I select correct supply voltage rails ? Also bias adjustment 🙂
V^2 / 8 =250
V^2 = 2000
V peak = 45V
- Many question about Threshold S/** supply rails
