hello.
need some help from u guys.
I am helping my friend to make a CD-Pro2 transport, he got his unit from daisy laser.
Now i need to decide on what power supply to use.
in the website, it recommend using a simple LM7805 / 7809 regulator will do. what you guys think, is it ok to use that to get very good sound?
anyway, i have this idea of adding a feedback to the regulator to make it perform better. Please give commend and advice.
This idea is very good in case, where extremly constant voltage is needed. In your case I would prefer extremly low noise and hum on the 5V rail. Therefore you need at first unit a normal regulator arround 12-15V and then a cascode current source, that loads a 5V power precision zener. You must choise the current so, that normal one half goes through the zener and the other half to cd player pcbs.
Do you still yet live in singapore?
