New/unused and very clearly industrial quality. I bought it but the size does not fit my casing and it is in this case very over rated with regards to power. Excellent specifications. Sturdy connectors for ring type crimp connectors. Since it is completely epoxy encapsulated no oxidation or things like that.
7.5A at 240V makes for 1.8 kW which should be sufficient in the Class A amplifier territory. I thought about filtering the whole group but decided on an audio mains filter for my relatively low power devices.
Specifications:
https://docs.rs-online.com/2aed/0900766b8140ec12.pdf
Yes that is 60 dB in normal and common mode (please see the frequencies) 🙂 I would like to have 75 Euro for it. Shipping only within Europe. Advice is to use an IEC inlet with built in fuse to connect to this filter.
Specifications:
