Magnat Plasma MP-02 Electrode and other
somebody knows what was the original electrode of Plasma Tweeters of Magnat model MP-02?
And what kind of material is it possible to use instead of the original?
Another question always on MP-02:
on the rear of the box there are 2 set of connector :
why?
perhaps because one set is the input of full range signal adn the other the output for mid-low for yhe mid-woofer?
Thanks,
MAX
Hello maxitu1, bear,
2 set of connector : I assume that that am simply only ground through,
durchgeschleift, to connect the main speaker.
ja, wolfram kann man nehmen, aber es hat den Nachteil, dass es als Katalysator wirkt wenn es glüht. Dadurch wird mit der Zeit die Oberfläche rauh und muss nachbearbeitet werden. Ich nehme jetzt Silber, das oxydiert nicht und es bildet sich keine Schlacke. Für den MP-02 wird ein Draht von 5mm Durchmesser richtig sein, unter passend gedreht mit der nut
jes, one can take tungsten, but it has the disadvantage that it works as catalyst if it glows. Thus will with the time the surface roughly and must be worked over again.
I take now silver, oxidized not and it form no cinder. For the MP-02 a wire turned by 5mm diameter to be correct,the lower part should be as formed as the original. It is also possible to regrind the old electrodes.
Best regards
George
