Right now there are cheap USB HDMI capture devices being sold on AliExpress, ebay, amazon and the likes. They cost less than $10/€10. These dongles expose a standard UVC webcam and a USB audio class soundcard to the system. The video is MJPEG encoded and the audio is lossless stereo 16bit 48kHz PCM.
For anyone running a crossover/convolver/other DSP on a Raspberry Pi this provides an easy method to get sound into your DSP computer. As it's just plain HDMI this works to add DSP processing to Chromecast devices, Apple TV, FireTV sticks and the likes and also regular computers independent of operating systems.
To make stereo capture work with Linux you need a very recent kernel that contains an ALSA configuration quirk. Without this the device is detected as a 16 bit 96000 mono capture device. The quirk has been added to the 5.8 kernel and if I understand correctly will also be backported to LTS kernels.
Even with the quirk in place the left and right channels are swapped but this can easily be dealt with in software - either remapping while grabbing with ffmpeg or system wide with pulseaudio remap-sink for example.
With the RC 6 of kernel 5.8 the audio capture device is detected correctly:
The video part works with any recent kernel and shows up like this:
While capturing is limited to 1080p30 with MJPEG compression (and 5fps lossless), the HDMI input supposedly accepts any signal up to 4k60 12bit. I have not tested this yet.
There is another version that has both an HDMI input and an output so the capture device can be inserted between a playback device and the TV. I ordered one of those to try next as that would allow me to extract audio from the HDMI link for DSP processing while leaving the video signal as it is.
Code:
arien@NBADJ01:~$ pactl list short sources
0 alsa_input.usb-MACROSILICON_2109-02.analog-stereo module-alsa-card.c s16le 2ch 48000Hz SUSPENDED
Code:
arien@NBADJ01:~$ sudo v4l2-ctl --all
Driver Info:
Driver name : uvcvideo
Card type : UVC Camera (534d:2109): USB Vid
Bus info : usb-0000:00:1a.0-1.1
Driver version : 5.8.0
Capabilities : 0x84a00001
Video Capture
Metadata Capture
Streaming
Extended Pix Format
Device Capabilities
Device Caps : 0x04200001
Video Capture
Streaming
Extended Pix Format
Media Driver Info:
Model : UVC Camera (534d:2109): USB Vid
Serial :
Media version : 5.8.0
Hardware revision: 0x00002100 (8448)
Interface Info:
Type : V4L Video
Entity Info:
Name : UVC Camera (534d:2109): USB Vid
Function : V4L2 I/O
Flags : default
Pad 0x01000007 : 0: Sink
Link 0x0200000d: from remote pad 0x100000a of entity 'Processing 2': Data, Enabled, Immutable
Priority: 2
Video input : 0 (Camera 1: ok)
Format Video Capture:
Width/Height : 1920/1080
Pixel Format : 'YUYV' (YUYV 4:2:2)
Field : None
Bytes per Line : 3840
Size Image : 4147200
Colorspace : sRGB
Transfer Function : Default (maps to sRGB)
YCbCr/HSV Encoding: Default (maps to ITU-R 601)
Quantization : Default (maps to Limited Range)
Flags :
Crop Capability Video Capture:
Bounds : Left 0, Top 0, Width 1920, Height 1080
Default : Left 0, Top 0, Width 1920, Height 1080
Pixel Aspect: 1/1
Selection Video Capture: crop_default, Left 0, Top 0, Width 1920, Height 1080, Flags:
Selection Video Capture: crop_bounds, Left 0, Top 0, Width 1920, Height 1080, Flags:
Streaming Parameters Video Capture:
Capabilities : timeperframe
Frames per second: 5.000 (5/1)
Read buffers : 0
brightness 0x00980900 (int) : min=-128 max=127 step=1 default=-11 value=-11
contrast 0x00980901 (int) : min=0 max=255 step=1 default=148 value=148
saturation 0x00980902 (int) : min=0 max=255 step=1 default=180 value=180
hue 0x00980903 (int) : min=-128 max=127 step=1 default=0 value=0
Sorry for bringing an old thread back to life but I recently purchased one of these MS2109 devices to try and extract the audio from a Chromecast's HDMI output and feed it to CamillaDSP on Ubuntu 22.04. The device seems to be detected properly in Ubuntu and when I open alsamixer the device is shown as a sound card with capture only capability. However, I don't know what else I would need to configure to get CamillaDSP to accept the audio from it.
https://henquist.github.io/0.4.2/#devices
You need to define a capture device for CamillaDSP to use. Should be similar to the example provided in the link above. The capture sample rate must be 48000, though. Also the name should be changed to whatever pulseaudio calls the device.
Should tell you what the device is called.
Bash:
