Friends! help connect the amplifier module on MA12070p (1.6v black board from Aliexpress, digital i2s input) with DSP adau1701
When connecting MCLK (amplifier-dsp) it gives an error when loading the firmware into the eprom. Following the advice, I connected MCLK to BCLK DSP. I set the settings (I hope that they are correct) in SigmaStudio as a result the sound from high volume speakers is distorted and it is not regulated by the volume level from adau1701 (from SigmaStudio). I assume that the volume level can be adjusted through the ma12070p registers using mh-tiny and arduino IDE, but I have not found information on how to do this anywhere.
What am I doing wrong? how to achieve results?
