M-Audio Delta 1010LT breakout cable pin allocation
Does anybody have the pin allocation for the breakout cable from the M-Audio Delta 1010LT Soundcard? There are a 15 pole high density female D-Sub connector for digital I/O and a 44-pole high density female D-Sub connector for analog I/O. I spent hours in the internet searching for but did not found it.
Did you ever find this info? If you did would you mind posting it here or sending it my way? I also have a 1010lt and probably have the same idea as you. Are you also considering building your own breakout box?
Did you try contacting M-Audio directly to see if they would send you this info? That is my next step.
