LynxTWO-A model, with four analog inputs and outputs with all of the breakout cables
This is a used full-size PCI sound card .
Lynx Two 24-bit/192kHz Multi-channel Audio Interface
A model also provide comprehensive digital I/O facilities: a single digital in and out in either AES-EBU or S/PDIF format.
All the analogue I/O emerges from an L2Audio 25-way D-type connector, which interfaces with a 1.8-metre-long multiway cable a full 14mm thick, terminating in eight XLR plugs and sockets
The Price for the used LynxTWO A Model with the breakout cables $450.00 Plus Shipping
Lowered Price $250.00 Plus Shipping
I would test the card in Windows 10 to make sure it is compatible and working. It may not be. I've had a few digital devices not work in 10 but fine in older OS.
