Browsing some spline papers I came across a reference to a work on splines in DA conversion. It seems like Masaru Kamada has made some DAs using splines, including the Luxman DA-07.
I'd really like to know more about this DAC. Going to library on Monday to order more papers. Meanwhile, does any one of you guys know more about this DAC or others using splines?
Greetings,
Børge
Greetings,
Børge
It's been a long time, but is this the paper you are referring to? (PDF) Fluency DA functions as non-uniform sampling functions for interpolating sampled-values
I know of atleast one software interpolator which does something similar today. It is called xxhighend, and he calls his interpolation algorithm "arc prediction" and it sounds really really good. Wonder if there's other similar papers on the topic.
How do I check if the above paper is open source, I would like to know if I am allowed to implement a modified version the fluency algorithm on other products/softwares.
