I have two LL1530 transformers left unused from a previous project, can anyone suggest how they might be saved from collecting dust, whether it's as part of a line stage or even in a power amp?
Datasheet is here:
http://www.lundahl.se/pdfs/datash/1530.pdf
Originally they were intended to be used between the i/v resistors of a DAC and its following SRPP tube stage, however after some experimentation there really was no need for the transformers.
Datasheet is here:
