LtSpice transformer - confusion
For simple modelling of SE OPT and IT I have used the standard method with inductors and a K directive.
The inductance ratio is the same as the transformer's impedance ratio - as described in the help files.
When I try to use the same method with a center-tapped primary I do not get the result I expected.
The voltage ratio works out as 1.4142 times that of the to the same transformer with a single primary. Consequently the impedance ratio is doubled. When I make the primary 10H+10H I get the same result as a single winding of 40H.
What am I doing wrong ? 😕
See the illustration below which is modelled with no loss or DC resistance to illustrate the point.
Svein.
