LTspice giving very poor THD results (one opamp test)
I'm playing around with LTspice and even with one singe opamp as buffer I get very large THD. anybody can point me to what I'm doing wrong ?
Harmonic Frequency Fourier Normalized Phase Normalized
Number [Hz] Component Component [degree] Phase [deg]
1 1.000e+03 4.894e+00 1.000e+00 0.18° 0.00°
2 2.000e+03 8.335e-05 1.703e-05 -153.42° -153.61°
3 3.000e+03 6.513e-02 1.331e-02 -165.32° -165.50°
4 4.000e+03 2.624e-05 5.362e-06 9.14° 8.96°
5 5.000e+03 3.068e-02 6.269e-03 6.51° 6.33°
6 6.000e+03 1.186e-04 2.424e-05 -8.84° -9.02°
7 7.000e+03 6.043e-03 1.235e-03 -29.63° -29.81°
8 8.000e+03 1.056e-04 2.157e-05 125.99° 125.81°
9 9.000e+03 4.735e-03 9.676e-04 -174.96° -175.14°
10 1.000e+04 2.753e-05 5.624e-06 -139.51° -139.70°
Total Harmonic Distortion: 1.479406%(1.515575%)
Perfect, all good now
Set to:
.tran 0 10ms 0 1us
.OPTIONS plotwinsize=0
.OPTIONS numdgt=7.
Tried with and without compression, this did not make a difference.
1 1.000e+03 5.000e+00 1.000e+00 -0.01° 0.00°
2 2.000e+03 3.711e-06 7.421e-07 -10.61° -10.61°
3 3.000e+03 4.666e-08 9.333e-09 79.12° 79.13°
4 4.000e+03 9.307e-10 1.861e-10 70.92° 70.93°
5 5.000e+03 1.315e-09 2.629e-10 36.03° 36.03°
6 6.000e+03 1.491e-09 2.982e-10 31.10° 31.10°
7 7.000e+03 1.671e-09 3.343e-10 27.00° 27.01°
8 8.000e+03 1.858e-09 3.715e-10 23.67° 23.67°
9 9.000e+03 2.048e-09 4.096e-10 20.90° 20.91°
10 1.000e+04 2.242e-09 4.484e-10 18.57° 18.58°
Total Harmonic Distortion: 0.000074%(0.000000%)
Don't trust spice opamp models... Look inside the subcircuit model first.
If the opamp is modeled just with E, F and G's, plus some RC to get the open loop response phase and gain, and there's just the output transistors models inside, then distortion will be wildly optimistic.
Why? Its an NE5532.
The idle current can be 16mA plus 2x3mA output (4k)
this makes 600mW dissipation for 15V rails or 880mW for 20V
The dice temp. will rise to 104°C or 130°C with 50°C ambient. (PDIP in fixture)
The high temp will not be beneficial, higher noise, lower gain, shorter life.
When a lower resistance is driven like a headphone the thing will fry, so cooling needs to be added.
That is why the
7.3 Recommended Operating Conditions MINMAXUNIT VCC +Supply voltage 5 15V VCC –Supply voltage –5–15V
