Hi
Any one know were i could get some LSK170c or equivalent JFET. I have searched the internet and cannot find anything.
the basics i need are N channel 1V to 2V VGS and 10mA to 20mA IDSS.
the Jfets are going in variable (for experimental purposes) CCS device to bias an OPamp in to class A
in this case would a Jfet with a negative VGS work?
Tom
I'm in the UK
Tom
I'm in the UK
LSK170 is a second source of 2SK170 (made by Toshiba but discontinued). For 10 ~ 20 mA, you need V rank, which is still available here and there. If this is for experiments, why don't you design a simple BJT based CCS, where you can have more freedom on the current setting?
Have fun!
Have fun!
you cant parallel a few lower IDSS parts? 2sk170BL are still pretty widely available including in the for sale and group buy section here in the forum, its only the P channel thats really hard to find legit. you can also find some 2sk369V around the place
Thanks for the replays.
For me the BF862 is easy to get hold of.
If I was to use the BF862 what would the best way to mount it on a prototype strip board?
I bought 2SK170BL from E-Bay with no issues.
4 X MATCHED 2SK170 2SK170BL 2SJ74 2SJ74BL FET! | eBay
http://www.ebay.co.uk/itm/4-X-MATCH...843?pt=LH_DefaultDomain_0&hash=item230dd5addb
The NXP Data Sheet doesn't say anything about noise performance in the audio range - only at 100 KHz. Is there a manufacturer who DOES spec this parameter? Or, are there at least some sample measurements that verify low noise at lower frequencies?BF862 -- surface mount -- from NXP --
Dale
It´s the 2SJ74 which becomes hard to get. The 2SK170 is still available from major
distributors:
2SK170BLF Toshiba JFET
LSK170 you can get here:
Micross Components | Products
distributors:
- Design & Build
- Parts
- lsk170c JFET or equivalent
