pair of PM4C
problems:
broken spider on one (looks repairable with some fine and steady neoprene glue jobie)
dead coils ; in fact-coils are good ,but drivers aren't used for long time,and connection between copper terminal wires (what is proper term for wire from terminal to cone?) and Alu coil is loose ;
any tips for Alu soldering ?
some particular solder ?
problems:
pair of PM4C
problems:
There is alu solder, and I can share a few cm's, but comeon this question is ages old . . .
I just bought Lowthers but one needs a new surround. I try to find out how to do that 🙁 as I do not want the cash layout for factory repair).
Suggestions?
yes Atelier Rullit would like to service them too and this looks like a good value/price compared to factory rejobbing.
tnx for reply
that issue somehow isn't an issue anymore 😉
for Lowther refoam - just search on ebay.de for Lowther and you'll find myriad of recone kits
I believe with little patience you can do it by your self
tnx for reply
A yes, the extension .DE is de secret 😉
I forget that the ebay sites are not linked together. Yes patience and some experience (e.g. I made Fostex 103 spider with wires ... )
albert
whenever I'm searchin' something on bay , I'm using extended search , with Europe as search area
in that case , you can use your local bay , but hits are from all over
