Low wattage Sub recommendations?
I have a dual output 25 watt amp running a Dayton rs100-8 and I'm looking to get a sub. I've looked around and can't find any subs that are around the amp's wattage. Any recommendations on drivers? I know I would need a crossover at some point...
Are you trying to drive the subs and your full range speakers with the same amp channels simultaneously? If you are, it's not the best idea but your goal will be to find sub drivers with similar sensitivity as your full rangers. This way you'll have less amp power wasted as heat from resistors in your passive crossover to attenuate one or the other driver. A better scenario would be to get an additional amp for your sub and use an active crossover to divide frequencies appropriate for each speaker and feed those signals to the separate amp channels driving each of them.
well with two amps you can vary the gain/volume to get a level match between the RS 100's and your new subs. so individual driver driver sensitivity is less critical with respect to matching.
you can change the levels between the hi(RS 100's) and the low(sub) ranges which is something you can't do with a passive crossover. (not to catch flak yes passive crossover levels are adjustable it's just not as easy)
after that there's the crossover to consider.
I have just started working with speakers a month or two ago and this is my first venture into crossovers... where are places I can find active crossovers for cheap? I see that they have them on parts express and on amazon but they are extremely expensive.
I mean use a Passive crossover and only use the tweeter output and leave the woofer one empty
No, you don't do that. Your active crossover will separate the subs from the full range. The passive crossover will separate the lows/mids from the highs. You don't want the woofer/midrange going into the range of the tweeter if you have a tweeter. That will lead to weird phase issues.
Do yourself a favor and do some reading on speaker and crossover design.
