Hi Hugh,
I'm changing my setup at the moment and with that I have to aquire some new loudspeaker cable. I have my I on supra-ply 3.4S but I was wondering if this is a good choice to be used with my NAKSA70 because it is a high capacitance cable. Mine would be around 22nF load to the amp. Is the NAKSA70 stable into that load or should I get something else?
It should be fine as this amp is highly stable into cap loads, Sjef.
BUT I would not spend a lot of money on speaker cable; I have in the past used thick 25A auto wire and it worked just fine.
Hugh
Hugh
Thanks for your answer,
I'm not going to spend much on cables indeed. I have been using cable talk 3.1 biwire for 25 years and it was allways just fine. Now I need some longer lengths and the Supra cable is cheap enough to try. I will report back if I hear any difference whatsoever. I don't expect much if any at all.
