I just played around with this $8 loudness volume control from China. It seems to have killed my bass, treble and made it dull. Do you think it's a good idea to add a JFET buffer after the pot ?
Japan AIKO 100K Equal Loudness Volume Control Dual Potentiometer Adapter Board | eBay
Thanks much.
Thanks much.
Looks great, but junk those PIO capacitors for a PP film type. Keep the jfet sound clear.
Or just change to a 10k pot. Cheaper, and no active circuit or coupling capacitors needed.
This will sound better. These are very good quality stepped resistor controls.
DACT Type 21 Stepped Attenuator / Potentiometer 10K * D Shape Shaft * HiFi grade | eBay
Will the DACT Type 21 Stepped Attenuator do the same thing as a loudness volume control ? So I can balance bass vs treble. I only found this guy:
Mshow Japan ALPS Volume control 27 type Dual potentiometer 10K 50k 100K RK27 Round shaft With adapter PCB|Amplifier|Consumer Electronics - AliExpress
Thanks.
Thanks.
