For Sale Lot of FT - teflon capacitors
Things you have for sale.
FT teflon capacitors and K72p-6 teflon sealed capacitors
all capacitors are checked for tolerances, mostly slightly more than nominal
a small number less than nominal
they are 5% 10% a small number 20%
to increase the capacity you can simply parallelize the capacitors
200 volts for transition
600 volts for power
200 volts 600 volts are working voltages these capacitors
allow this voltage to increase up to 40%
paypal payment
exchange for radio tubes is possible by agreement
1 K72p-6 0.1*200V-1pcs 68N*200V-2pcs 56N*500V-3pcs 18N*200V-2pcs 10N*200V-1pcs 1n*500v-2pcs
+ CAP Siemens 0,5mF*220V\400V ??
60$
2 FT-1\FT-2 47N*200V-3pcs 22N*600V-1pcs 22N*200V-1pcs 18N*600V-2pcs 15N*200V-1pcs
10N*200V-3pcs 10N*600V-1pcs 8N2*200V-2pcs
30$
3 FT-1 3000pF*200V-151pcs new in factory packaging
+ FT-1 3000pF*200V-55pcs used
90$
4 FT 5600pF*200V-1pcs 4700pF*200V-1pcs 4300pF*600V-7pcs 3900pF*600V-8pcs 3000pF*600V-8pcs
1600pF*600V-2pcs
2200pF*200V-2pcs 1800pF*200V-5pcs 1300pF*600V-2pcs 1200pF*600V-2pcs 1100pF*600V-4pcs
1000pF*600V-19pcs
820pF*600V-23pcs 680pF*200V-4pcs
510pF*600V-5pcs
50$
all together 200$
