The "GRAB BAG" has the following:
1 NEW Sorbothane Damping Sheet 1/4" Thick X ~5" X ~4" Duro70 Strength
6 Bolt - Nut with Sorbothane Washer / Sorbothane Bushing for ISOLATING cabinets / stands / staggered speaker cabinets (i.e. mid enclosures on top of bass cabinets etc.)
8 New Rubber feet (3/4" High X 1-1/4" diameter) with integral washer
8 Used Rubber feet (3/4" High X 1-1/4" diameter) with integral washer
LOT of "scrap" 1/4" White F13 FELT - the BEST sound absorbing FELT available (expensive)
1 NEW True 75ohm BNC (6ft) ideal for DAC to transport connection (Low Jitter)
1 NEW USB 3.0 10ft cable
1 Used 15ft USB "extender" cable
1 NEW Laser Assembly for California Audio Labs ICON II / CL-10 / CL-15 CD Players
2 Jantzen Standard Metalized Polypropylene 4.7uF 400VDC
2 Jantzen Standard Metalized Polypropylene 6.8uF 400VDC
2 NEW Female XLR RFI-EMI Noise Reducer "Cap"
10 NEW Female RCA RFI-EMI Noise Reducer "Cap"
5 Used 6' foot long FT4 16AWG Plenum / In-wall OFC Stereo Cable (Some with Nakamichi Banana Plugs)
2 Wooden Gold Binding Post Assemblies with Rings or soldered stereo FT4 speaker cables ( 5 cables each 3' to 5' long)
LOT of 16 Gauge 16 Gauge twisted stereo Pair SOLID Core speaker or connect cables
100 NEW Neutrik " NLFASTON Crimp connectors 14-16 wire
1 Origin Acoustics "Preamp" (requires 24VDC Power Supply)
12 Miscellaneous circuit boards from Sonance 2120 Cinema / Sonamp 260 power amps
100+ NEW Miscellaneous 1/2 Watt Metal Film / 1 Watt Metal Oxide Power
8 New / Used 6 Ohm 50W Heat-Sink Resistors with Flying Leads
20 Misc Transistors TO91 500mW / TO-202 1.5A etc.
20 Misc. Diodes - 1 Amp Power & 1N4148
12 Misc Resistors - 1/4W & 1 Watt
7 - 6 Amp Type DO-41 Power Diodes
5 - 0.1uF 160VDC Film Capacitors
5 - 18VDC Zener Diodes
"Bunch" of Static-Free Electronic Component Bags
A few small polarized capacitors
3 DPDT High Power Relays - 1 New; 2 USED
The following PS Capacitors are all fully functional:
10 Used 10,000uF 63V 85°C (4 Euro-Cap from Sugden AU41) + (6 from Sonamp 2120T = 2 ELNA + 4 UCC)
12 Used 15,000uF 63V 85°C (12 Lelon from Sonamp 260 MK II)
2 Used 6,800 uF 50V 85°C (2 from Rotel 931B Integrated)
4 Used 10,000uF 63V Radial Electrolytic Caps
They are all 35mm in diameter (except the 6,800uF which are 25mm) and are 40 - 50mm in height
SOLD to Ed*
SOLD to Ed*
