Hi All,
I am looking for the W-Input module designed by Tomi Nihtila. If anyone is willing to sell the module, id be interested to buy.
Thanks and Regards,
Som
Thanks and Regards,
Som
Hi ML,
Thanks for getting back. I am actually looking for the W-Input board. The one you have is the software-controlled version of the Compact S/PDIF receiver board.
the one i am looking for is this.
I'm looking for the same board myself or something like it, need USB and Coax inputs with I2S output.
I cant believe no one is producing input boards.
The software interface is above my ability....
i agree .. i was in touch with Tomi himself, but he says he is unable to produce anymore AKM based boards due to unavailability..
I am so badly waiting for someone here to come up with a very nice input module that can be used in all our DIY dac builds.
This one works for the Coax/Toslink inputs and also switches an external I2S, typically from a separate USB card :I'm looking for the same board myself or something like it, need USB and Coax inputs with I2S output.
https://www.aliexpress.com/item/100...!sea!HK!2609685283&curPageLogUid=U5GDOD3IqVUM
It appears that is software controlled but also shows a switch. Its unclear how that switch works.
OP1 short shows auto selection on Coax/optical but not sure how I2s input works
6.Key switch for input conversion, with memory, there are two modes:
OP1 open -> select coaxial 1/coaxial 2/optical/I2S input respectively
OP1 short circuit (default) ----> coaxial 1/coaxial 2/optical automatic selection and I2S input
7. LED light or display screen display choice
OP2 open circuit (default) ----> display
OP2 short circuit---->LED light, that input will light up the LED of that way
Many months ago when I played with one of these I had it so the single push switch cycles through the various inputs in turn.
Makes sense, I would assume its one of these key switches circled?
Was the sound quality good? The clock looks cheap....I have a good USB interface so the I2S pass thru shouldn't degrade the signal.
Bump. Anyone willing to let goHi All,
Thanks and Regards,
Som
