Looking for this connector
Our Roborock S5 stopped working, and in the process of trying to fix it, I destroyed this connector. Does someone know which sort of connector this is, and where I can buy a replacement?
The outer dimension are 12*6*13mm (LWH). The pins come out in a 4x3 pattern. The counterpart is a PCB, with traces, so this is sort of a edge card connector.
many thanks!
Erik
many thanks!
Erik
No idea, but why not read this article, and email the manufacturers your picture and see what you get?
https://connectorsupplier.com/card-edge-connectors/
Digikey has just about everything. It might take some work to identify this connector, but I'd bet they have it.
Eliminate the connector, use wires directly, dexterity permitting.
Do check if the unit is dead or alive.
Not much point in fixing a dead unit.
many thanks for all the replies. yes, identifying it would be the trick: I looked through several pages already, but unfortunately nothing.
I thought about replacing with wires, it will be a bit cumbersome, but maybe indeed faster. Will be a nice job for tomorrow at home!
Thanks again, Erik
Thanks again, Erik
- Design & Build
- Parts
- Looking for this conector
