Hi folks,
The volume pot on my Macintosh C24 is failing, so I'd love recommendations for where to obtain a reputable new, NOS or healthy used one. I've gone through the Deoxit routine.
I see a few new options on eBay, but have no idea how reputable those are and Audio Classics doesn't have anything in stock.
I apologize if this is redundant relative to previous posts, but I tried a few quick searches here with no luck based on thread subject lines (and I'm a rank newbee, so maybe searching the wrong forum?).
Thanks for any suggestions!
Mouser sells potentiometers but as you have a Macintosh I will guess you are located in the USA , if so this NJ company sells military spec. and commercial and has dual 750Kohm and 1Megohm dual.
They will also do them to your specifications.
https://potentiometers.com/pdf/Milpdf.pdf
Thanks, I'll try them tomorrow or on Monday. I'll need to check out the details such as Ohm range, spindle size/thread, etc. in order to spec one out from scratch or from their catalog.
The C24 volume pot has a loudness tap which might be hard to find. But if you get desperate and have money to burn.
McIntosh Volume Pot control for MA5100 MA230 C24 loudness potentiometer | eBay
£64 -Pounds for a volume control ?? , only in 2021 would prices like this apply --absolute insanity !
I have plenty of old collector electronic gear --must make me a potential future ££££££-$$$$$$$$ millionaire.
