Hello,
I recently finished my first vacuum tube line preamp. Its a simple design, with a regulated power supply and a couple of 6SN7GTs, one for each channel, gain 10. Im very happy with the results, except when Im listening at very low volume, during late night hours. I feel that a loudness control would be helpful in such moments, but I wasnt able to find a suitable circuit anywhere.
Can someone help me and point out a book or website with a schematic or formulae for a simple passive loudness control? Or, even better, for a tube based active variable loudness control?
Thanks in advance,
Norman
Thanks in advance,
Norman
This is a link to a page on Steve Bench's site. It includes some circuits, although passive rather than active.
http://members.aol.com/sbench/freqres3.html
Thanks Robert, that hit the spot!
The only bad thing is that I use a 100k volume potentiometer, and those circuits expect a 500k pot.
Perhaps someone can help on this subject? Any tips on recalculating those circuits?
Thanks in advance,
Norman
Thanks in advance,
Norman
convert to 100K pot
To convert the designs from a 500K pot to a 100K pot, divide all resistances and inductances by 5, and multiply all capacitances by 5. This will result in a circuit with the same frequency response, but 1/5 the impedance.
A kluge that has been used with some success in the past is to use a parallel combination of resistor, cap and half of a dpdt switch connected between chassis ground point and the cold (gnd) end of the volume pot.
Start with a resistor of about 10K and a 0.12uF cap, increase cap to lower maximum boost frequency. Adjust both to taste.
Increasing cap value lowers point at which boost ends. F=1/(2piRC)
Larger resistor increases amount of boost, decrease cap value by ratio of r_old/r_new. So double resistor, halve cap value..
Smaller resistor reduces boost, increase cap value as by above. Halve resister, double cap value.
