hello everybody,
it's time to buy a new amp;
i have asked this question before, but it is an old topic, so here i go again.
what amp delivers the best sound for around 100 euro?
i guess i have to stick with a class D amp. I have one, it is a heavy modded charlize t2020, and it does sound good, but when i listen to a tube amp, it is less dry, more musical...
so can anybody tell me what the best sounding amp is. I'm looking at arjen helders site, 41hz, hifdiymedia...
lest time i checked the 2050 was ruler of the pack ?
ps: i would like to have a bit more then 10 watts, 30 would do fine.
thanks so much
thanks so much
If you have already tried the Charlize, there is not much better to be had in class-D!
Trie it on a battery, maybe that is what you are looking for
well late at night, the charlize does sound much much better, i guess a cleaner line makes the difference.
i don't want a second charlize, (that's the reason: i need a second amp for my living room).
but maybe i should insert a tube as preamp on my charlize, what do you think ?
i use a gamma dac 1, and i'm looking for an upgrade too, i will use the gamma 1 at work.
thanks to point out that after 5 years the charlize is still a-o-k
