Looking for driver suggestions
From wherever you are located find a vendor that has some drivers that are in your price range.
Obtain their parameters and enter them into a design / simulation program like WinISD (or other) using the volume of the cabinet that you have.
See which one looks like it will work...avoid large peaks in the response and check for efficiency.
Some suppliers will have notes on the drivers they have that will suggest a certain size of cabinet... look for that.
Other than that someone else may have already designed a 5.5ft^2 and know what to use.
Good luck.
