Looking for a good NPN audio driver for my power amp.
I have used BD829 as audio driver. They don’t make them any longer. Anyone no what I can use instead?
I have the 2SC2922 for the output in my power amplifier. Can any one tell me what is very good audio transistor NPN who I can use as a driver before the 2SC2922?
Regard
Progg70
you could try
2sa649/c669 120V
2sa649a/c669a 160V
2sa1535/c3944 150V
2sa1535a/c3944a 180V
2sa1220/c2690 120V
2sa1225/c2983 160V
2sa1606/c4159 160V
2sa1930/c5171 180V
which all have fT > 80MHz, but some have a poor high voltage SOAR.
for a slower, fT 30 to 40MHz, but very robust driver then try
MJL15032/3
MJL15034/5
Dear Progg70,
BD829 is a 80V, 1,5A, 8W, 250MHz device in TO-202 package.
Let's use BD139 instead them. It's a dirty cheap, "always available" device, with 80V, 1,5A, 8W (improved to 12,5W), 250MHz specifications, in TO-126 package.
Regards,
Geoff said:
The Philips datasheets (the only ones that I have found for these devices that quote the fT) give 190MHz for the BD139 and 160MHz for the BD140 (@ Ic = 5mA, Vce = 5V, f = 100MHz)
True, but many manufacturers don't spec ft at all for these transistors. That doesn't necessarily mean theirs are worse, but they don't promise anything, so who knows? For instance, since the threadstarter will probably buy them from Elfa, he will get ON devices, which have no ft spec in the datasheet. Ironically, Elfa used to sell Philips devices of these types, but have now switched to ON.
