Locating Preamp Output Transformers
Can anyone point me toward some decent but not too expensive preamp output transformers? Something like 10K:600 to plate load a 6sn7/6j5 or something similar. I have a pair of edcors, but am looking for something a bit higher in quality, but less expensive than the electra prints. Thoughts?
Lundahl 1660S
They are $85 or so each, but they are electrostatically shielded
and are fantastic for a PP 6SN7 driving 600 ohms out. In fact,
they were made for this application. Everything else is $100 each, Sowter (when you factor in currency and shipping), Jensen, etc.
I did also of work with the Edcors, both the 10K:600 and
the 10K:150. They cant take much DC imbalance, so I abandoned
PP triodes driving the Edcors and tried running them parafeed SE.
That worked out much better for bass response. I also had to use
a low Rp tube to get the bass I wanted, 5687s, not 6CG7s.
Despite the limitations with Edcors as a line-out, they work
fantastically as line-in and phase splitters. I've been driving
10K:10K with a solid-state differential line chip (Analog SSM2142).
They sound fantasticc, with a solid state driver to boot.... 🙂
-- Jim
