LME48910 biasing...
The schematic is in the datasheet here.
If someone good help me with some of these it would be great!
1. I wonder about the Vbe multiplier they have displayed and talk about in the text. It says that 2.8mA is a good value to flow from BIASm to BIASp but out of interest how would I work this out not know the voltage presented by these two pins? I know it's knot a simple as putting a resistor there but I would like to know more.
2. Also they talk about a bias formula which I haven't got a clue about.
3. I prefer to use FETs so could I just use diodes and forget the Vbe because I don't have to worry about thermal runaway? I want to use IRFP240 and it's partner. How would I implement this?
Boscoe
Hi Boscoe,
Datasheet says
The LME49810 has two dedicated pins (BIASM and BIASP) for Bias setup and provide a constant current source of about 2.8mA.
so there's a current source and whatever voltage difference you want you can obtain by choosing suitable total resistance in your vbe-multiplier 😉
Fets are sensitive to thermal runaway! Their zero tempco point you refer to is at several amps for vertical types as the IRFP240!
Hannes
