I'm having a strange problem with a gainclone I jut built. When I first power it up, it sounds great, but then after a couple of seconds a fuzzy distortion sets in both channels. If I power off and back on, the same thing happens. The heat sinks are not too hot. Any ideas what it could be?
This is the first time I'm using non-insulated chips. I have properly insulated them with mica. No shorts anywhere.
how hot is the chipamp?
Could any of the polarised caps be back to front?
Are you still running it through a bulb tester?
