Howdy all,
New to the forums and DYI electronics.. but I have a infocus litepro570 projector that I used to use quite a bit.. After my first bulb blew I took it to a repair shop and paid a hefty cost for a new bulb and a "Servicing". now only a year later the light won't come on..
I read the manual regarding bulb replacement and after taking the bulb out... it looks pristine... I can see the unit is powering up... if I tap the standby switch on the remote the power led flashes.. and then tapping again it goes solid green so I imagine it is mode switching..
Could it be a ballast thing? if so where would that be accesable?
Thanks in advance for any input!
Brad
Brad
