links in wiki table of contents
Contents list has hyperlinks to each section. The link isn't much good for copy/pasting thoguh, currently link in there is in the form:
www[dot]diyaudio[dot]com/forums/#[section name]
What it really should be is:
www[dot]diyaudio[dot]com/wiki/[wiki page name]#[section name]
Hopefully the above makes sense. It's not an issue until you try to copy and paste a link directly to a specific section in a wiki page, the current link works when you're on the page but is not something that you can copy and paste into a forum post.
This is easy enough for me to edit by hand and create the direct link but it seems unintuitive for less technically minded types.
Thanks,
Chris
