LinearSystems LSK389 compliment to the Toshiba 2SJ109?
Hello dear community,
I own some original Toshiba 2SJ109 because I wanted to build the AlephJ.
Now I'm interested in JeffDeGaar's Up-Amp...
The LSK389 is currently available from LinarSystems, can I use this as a compliment to the 2SJ109 and these differential amplifiers according to Papas Susy?
Thank you for your help!
Best regards
Mike
The NAC Group appears to have the LSK389 in TO-71 and SOIC packages in stock. I have ordered other Linear Systems parts from these folks in the past without issue. They are listed as a "worldwide online" distributor on Linear Systems' website, so with luck they will deliver to Germany.
Hi, the delivery is not a problem, Digikey has it and delivers to Germany without any problems.
I'm interested in whether they work in conjunction with the 2SJ109 in the UGS from Jeff DeGaar'S UP-Amp.
I think yes, they should correspond to the Toshibas.
The original Toshiba 2SK389BL has a Yfs of circa 20mS,
Toshiba 2SJ109BL has a Yfs of circa 22mS.
Linear Systems LSK389BL has a Yfs of minimum 8mS in the datasheet.
Will it fit as a complementary pair/ quartet? You will have to try.
Cheers
Dirk
Uh, yeah, sorry about that. 😳 I'm so preconditioned to part unavailability that I added an "un" in front of your "available".
