My line stage consists of a grounded cathode amp cascaded into a cathode follower.
The tube is ECC99 and the operating point is 150V@18 mA each section.
B+ is 360V, load resistor and CF cathode resistor are 10k.
My measurements showed that the GC section draws 18mA but the CF section draws 16,5 mA.
Why ?
Should I reduce the CF cathode resistor at 9,7K to achieve equal current draw and cathode
to plate voltage ?
Mic
Why ?
to plate voltage ?
Mic
> achieve equal current draw and cathode to plate voltage?
Why? What possible advantage could there be?
PRR said:Why? What possible advantage could there be?
Perhaps to cancel some distortion by operating both valves (of the same type) at the same operating point? 😕
Hmm, I seem to remember something about this from way back.
Wasn't it something about this on the Audio Genesis website? ( now gone )
Something to do with the power supply and subjective dynamics, I believe.
I may be wrong.
cheers 😉
I may be wrong.
cheers 😉
I remember reading something like that in an old issue of the "Tube CAD Journal" also... I think it was the cathode follower issue.slowmotion said:Something to do with the power supply and subjective dynamics, I believe.
Best regards,
Mikkel C. Simonsen
Hi mcs
You're right it was in "Tube CAD Journal",October '99, page 3.
http://www.tubecad.com/october99/page3.html
cheers 😉
cheers 😉
Pff... sounds like BS to me...
Besides, a CF doesn't produce distortion so it can't cancel any.
Tim
Tim
Tim, the idea was that there is a cancellation at the supply end; at AC, as the inverting amp's current drops, the CF's current increases by a near identical amount. So it's a valid way of optimizing a circuit to use with weedy supplies and inadequate bypassing. Of course, it begs the obvious question...
As I'm not an expert, I would like to know if this non-symmetrical operation between the two sections of the same tube is something to worry about.
Normally, each triode shares the same load resistance and current draw. So, in my case I expect to see each section to draw 18mA.
But no, they don't. As I said before the GC section draws 18mA@153V and the CF draws 16.5mA@158V.
Maybe it is not such a big issue and to my ears it performs quite good.
Thanks for your replies.
Good one Tim. You are very wrong though...
Ok. So tell me, when's the last time you could measure any distortion produced by a typical CF such as the circuit in question, at line (listening) levels such as 1Vp-p or less?
...Yes, it is technically measurable. But using an instrument capable of resolving 0.001% or less is cheating. 😀
Tim
- Tubes / Valves
- Line stage question
