Line magnetic 211ia tube integrated amp (upgraded) - UK only
Selling my upgraded LM-211ia :
  • Purchased in January 2021, upgrades done in March 2021.
  • Point to point wiring
  • Tubes have around 800 hours
  • Miflex KPCU-01 coupling caps, KFPM-01 on the input, Mundorf Mlytic.
  • entire new rectifier with better diodes and larger caps plus some resistors changed along the way (the pictures show the upgrades probably better)
It’s equipped with Gold Lion KT-77 on the power stage and Gold Lion 12AU7/12AX7 on the input stage (over 300£ of upgrades).
Comes with original box, manual and remote control, pristine condition.
Selling as I've upgraded to a more powerful amp better suited for my speakers.
A listening session is recommended to appreciate the sound quality over the original setup (location: Sheffield, UK).
I want to avoid shipping if possible because of the weight (around 22kg) is a bit of a problem; shipping price is not included (estimated 20-30£ in UK).
Of course if you do need it shipped please contact me.
Review > http://www.acoustic-dimension.com/L...Magnetic-Audio-211IA-integrated-amplifier.htm
Full details here > https://www.line-magnetic.eu/en/pro...ificateur-intégré-push-pull-el34-2x32w-detail
The Line Magnetic integrated amplifier LM-211IA is a push pull amplifier with 4x EL34 tubes in Class AB amplification and delivers 2x15W in triode mode and 2 x 32W in ultra-linear mode.
Input stage: 2x 12AX7 and 2x 12AU7
Power stage: 4x EL34 (can be swapped with KT77 or 6CA7)
Specifications
Class AB amplifier
2x15W RMS Triode 2x32W RMS Ultra-linear
Tubes: 2x 12AX7, 2x 12AU7, 4x EL34
THD: 1% (1kHz)
Signal/Noise ratio: 88dB (Weighted A)
Frequency response: 10 à 50.000 Hz (-1.5 dB)
Sensitivity: 200 mV (Built-in Mode)
Input Impedance: 100kΩ
Asking price 900£
Reactions: DSummer
