I recently bought the Arta Suite, then build a measurment box for use with an amp, but there is 2 strange things with LIMP :
1/
After calibration, if I measure a 8,2Ohms Resistor I obtain a flat Impedance curve (under 10KHz) at 8,6Ohms, so ok, I write "0,4 Ohms" in the "cable compensation".
But after that the measure is ... 9 Ohms !!
I tried with bigest values and it is always the same result : " Cable compensation" value is added to the curve instead of been substracted.
2/
I obtained coherent results with all speakers I measured.
All ... but one ;-)
When I measure Visaton FR10-8 (3 differents) I obtain an inverted impedance curve, with the impedance near zero at Fs !?
I don't undestand this strange things, so I don't trust my others previous measurements anymore :-(
Maybe a problem with my box ?
Thank for read me
Arnaud
1/
2/
All ... but one ;-)
Thank for read me
Arnaud
Try to input -0.4R for the cable compensation and it should work. Can you post the other measurement?
