Help!
I've got a next to useless XGA here as I was sent the wrong cables with it and no way to get the right ones so I'll make up my own if I can get the pinouts worked out.
If you have one of these can someone please work out the pins for it from your cables? The AV connector is more important than the VGA, but both shown here:
AV connetor external:
AV connector top of PCB:
AV connector bottom of PCB:
VGA cable connections:
If you have the right cables and the same model, you could just do continuity down the leads and find the pin outs on the PCB for me and let us know what they are. 😀
MM
MM
