Lightning Audio LA-1000MD
If you leave all gains full up and increase the input level until it cuts off, does it cut off at the same point (changing NOTHING on the amp, only changing the input level from the signal source)?
What's the DC voltage across the B+ and ground terminals of the amp when the amp cuts out?
