Can these cheap 12v lighting units be used for heater filaments?
20-50watts at 12v apparently.
Or will they create huge amounts of noise because of the high frequency?
Hello,
Yes,I've used that for 6080 filament with very good result.
No,no noise at all.Mine amp's b+ was SS rectify form 120v isolate transformer.
More info available if you wanted.
Cheers!
SS
Cheers!
SS
I have successfully been using battery charger transformers for a SET amp for several years, now, both as filament and B+ voltage (by reversing the transformer 12 to 230v)
Fred Nachbaur also recommended using wall-wart transformers in his designs.
Just make sure they are isolating transformers.
