lifting the earth
When taking a Parasound A23 apart, I noticed that their ground lift switch implements the ground lift by capacitively coupling signal ground to chassis ground through the parallel combination of 100 nF and (I think) 10 uF. The goal here is to create a high impedance between the two grounds so no current flows. You want some impedance there to avoid HF instability and/or EMI issues, hence, the use of a capacitor.
~Tom
