LF356 ST versus LF356 NS
Both are serious Companies, so both should perform very well, meeting or exceeding specs, so end result should be same, or very vry close.
There might be small chip to chip differences, explained by normal manufacturing tolerances.
And that even in same brand chips, just different production batch, doubt any would be audible, specially because of the way Op Amps are used: HEAVY feedback so NFB network is way more important than small internal differences.
Unless you use them open loop, that is.
