LF driver help
I have a FR 8" Diatone alnico driver in a 1cu ft enclosure which is ported. I like it, but bass is lacking. I was thinking of installing a 8" woofer to the rear of the cabinet and running it so I get a push-pull effect. I would have to attach it to the outside on the back, and face it towards the front speaker ( not enough depth to put it inside). Anyone ever try this? Diatone is 4 ohm...so how to connect...in series?
Suggest OP try using the other main driver push-pull as a gold standard, then replace with something different and compare. Another similarly built FR driver might work better than a modern woofer. In my case, two very different-sounding vintage alnico 7x10 push-pull gave me the best of both worlds (LorenzGraetz-Goodmans, wrote about it somewhere). But my first suggestion is to divide the 27L chamber into a folded tapered line -- by adding cardboard incrementally (comparing left & right speakers in ladder-climbing fashion) and fine-tune until further extension no longer lower the bass reach. This MLTL-after-the-fact trick works especially well for lower Qts drivers in small cabs.
Reactions: NeonDriver and GM
